Soft top... I had the doors off, but didn't take pictures. Had to go to work.
Is that a new soft top,,if so, how many miles did you get out of your old one...?? just curious..
Installed LOD roof rack..
Flashing my colors..View attachment 158349
It's the one from the white jeep.Is that a new soft top,,if so, how many miles did you get out of your old one...?? just curious..
Olram had a hard top before.
Had a bit of a click in the front driver side. I think it was the sway bar at the lower bracket. Took the time to grind off the cross member since the sway bar rubs.
View attachment 158927.
View attachment 158930.
Also took the time to mark the suspension bolts
View attachment 158932.
I have been having this issue when I make sharp left or right turns at times at low speed. I am going to do the same thing as I noticed rubbing there too. Did it fix your issue? Gif idea Marking those bolts.
