Friday night I was going down the highway and the rear locker light started randomly flashing (shortly after going over a hard-ish bump). After a while it would flash constantly and stop for a while.
Since it did not feel like the locker was actually engaged, I drove it home and unplugged the battery overnight to see if resetting the ECU would clear it. No such luck. It does not come on right way while driving now, but after a bout 10 mins it will start flashing and then go out for 5-10 mins before flashing some more.
With the diff cover off I had someone engage and disengage the rear locker while I watched inside the diff. I can see thin disk (green arrow in pic below) move a little when it engages and the dash light stays solid. When we hit the switch to disengage the locker, that thin disks moves again, but the dash light keeps flashing. I can then put it in 2 Hi and drive around and can tell that the locker is not engaged, so I know it is not getting stuck in either condition.
Here is a pic of the inside of my rear diff:
And here is a pic a friend of mine sent of his (can't get it to post in line here at work, so it's attached below)
And finally one I found off the internet:
In my pic and the one from the internet, the triangular part with the tab on the end of is not engaged with the slot on the ring to the left of it (blue arrow). In my friend pic it is. Can anyone tell me if the tab should be in that notch and if so, under what conditions?
If you look at the red arrow, it also looks like mine might be bent as well, any thoughts on what might cause that??
Finally, here are two short (couple of seconds each) vids of how things move about in there (sorry the vids are sideways from my cell phone):
Video 1
Video 2
Should that ring with the notch in it rotate that much back and forth?
Thanks for your time and any help you can give me.
Video 1
Video 2
