Can anyone point me to a thread on these or help me understand how they work/are they worth my money
It will make disconnecting your sway bar a ton easier. As for explaining what the difference between a disconnected sway bar and a connected one this will help you visualize it. https://www.youtube.com/watch?v=yzqzrOqF3dI
In the video you will see that all he has to do to disconnect his sway bars (which he forgot to do) is press a button in the cab and that is because its a rubicon with the electronic sway bar. All other model jeeps (Sahara, Sport, Freedom Edition, Willys Wheeler etc..) do not come with this and you will have to manually unbolt the sway bar links to be disconnected. Getting quick disconnects removes the need to unbolt anything but instead all you need to do is remove a pin and whack the sway bar links off the axle mounts.
Below are the stock sway bar links which as you can see have bolts you would have to undo to disconnect.
These are quick disconnets. As you can see there is a bolt on one side and a pin on the other. (Makes life alot easier and are defiently a wise investment)
Ahh I see he can get a whole lot more flex with it disconnected, thanks for the help looks like I'll be looking to purchase a pair now
Just my experience but.
I had Tera Flex and my tires rubbed at full stuff and turn on the retaining bracket. I switched to JKS and have been very happy. Both great products, but my 2.5 lift and 35's made the TF discos rub.
There may be others that work, but that's my $.02.
I'm going to be running a 2.5 RK I might get JKS quick discos JKS seems to have good products
I run Currie antirocks front and rear. Don't have to worry about disconnecting. I had jks prior to this. The only thing better than not having to use a wrench and socket is not even having to get out of the jeep except to air down.
Jks is the best!
Before you purchase make sure your lift doesn't come with them already. Im pretty sure most RK kits come with quick disconnects.
True! Can you help me figure out if I have them I might already I bought the kit from northridge, it's the kit with bilstein shocks. I saw some away bar connects in the photo I just don't know if they are the quick disconnects
Post up a link to the kit you got.
Yep it comes with them.
Well at least I know how/what to use them for now haha
When I was running discos I took the rear swaybar off completely. It was great for daily driving. Takes a little getting use to.
What was better about it?
