WillyJKU14
Ok so I got back from Big Bear Friday ran Dishpan Springs and Holcomb Creek. Cleaned up the jeep Saturday. Went underneath to check out any damage.
I saw a groove in my right rear shock was messing with that then saw a rub mark in my brake line. Luckily it hasn't gone thru to leak fluid. So do I need to reposition my reservoir or just move the brake line to a new position?
Also noticed that my rear diff has a slow leak. Nothing has dripped. I touched the bottom and noticed it was wet with fluid. When I wipe it off and check back a few hours later it's wet again.
I just did my first differential fluid change at 15k. So I didn't pull the cover. I think I may have just snagged the lip on some rocks. So my question is do I go ahead and upgrade my covers? Or do I just remove it clean it up and re seal it back on to see if it will still hold?
