AllAmerican...what hitch set up are you running there? How does it handle?
I do not undestand why the max load is so little for jeeps in america.
In my manual that come with my 2012 saharah 4 doors( live in sweden so it is a export jeep with the unbeliable ugly front bumper ) the 4 door rubicon has the highest load capability. All 2 doors are only good for 1000 kg exept the rubi with six speed manuel that is alowed to tow 2000 kg. The rubicon automatic with pentastar is allowed to tow 3500 kg and that is about 7700 pounds. with diesel it is only 2500 kg with manuel six speed and ionly 2200 kg with automatic.
Rubi 4 door with six speed manual and pentastar is only allowed to tow 2000 kg instead of 3500 kg. So in this case the automatic can take much more.
the saharh with manuel or automatic and 3,73 is allowed to tow 2000 kg. a saharah and rubicon with pentastar and automatic shhould be the same car in terms of tow capacity but it still differ 1500 kg. that must be because of 3,73 vs 4,10 axle ratio.
anyway the rubi with 4,10 axle ratio and 4 doors with pentastar and automatic can according to the book tow most of them all and that is 3500 kg which is about 7 700 punds. Numbers that seems not to be ok in the states but ok here. I wonder why.
I also wonder why my saharh is only good for 2000 kg ( 4 400 punds ) because the only diggerence is 3,73 vs 4,10. is 4,10 so much stronger?
Trailer Brake Controller.... and conversion from flat-4 to 7-pin for controller...
Found this converter from Hopkins (from existing 4-flat to 7-Rpound or 4-flat):
Basically pug in the adaptor into your existing 4-flat, the new connector has a 4-flat on the side and a 7-round. The 7-round has direct connection to the 4-flat points (tail lights, brake lights, turn signals) but then also has leads to go to a brake controller for ebrake output and to battery for center aux power supply pin. Anyone used one of these? It looks like a pretty simple set up.
Is there a simpler/more cost effective way to convert my existing 4-flat to a 7-round so that I can add/have controller for trailer ebrakes for the pop-up camper?
Next question is am I good using the old brake controller I pulled from my Expedition (probably 10+ years old) or am I better off dropping the coin on a new unit like the P3?
Comments/Suggestions?
If I'm understanding correctly, you're asking if you can just use an adapter to convert to 7 pin..and the answer is not exactly. You'll need something like this http://www.etrailer.com/p-ETBC7.html to convert to a 7 pin and be able to use your old brake controller. It will add the wiring you'll need for the brake controller and tap into your existing 4pin.
Thanks for reply but not exactly what I was asking, I likely wasn't clear... Wiring Adaptor connects to the existing 4-flat (which I have on Jeep now) so those wire essentially go directly to the proper prongs on the 7-round (lights), then the back of the 7-round also was additional wires that are to be connected to ground, the ebrake controller and the battery for connection to those prongs on the 7-round (ebrakes, aux power). Just wondering if any one has used one of these adaptors and if so what their experience was.
Then second question is regarding using an old Brake Controller versus dropping cash on a new on like the P3 that I see number of members have used?
... Take it to a trailer shop if you are and make sure its wired right. They also have a nice tester that just plugs in and can make sure all the wires are set right.
I have used this adapter for a long time on trucks, haven't had any problems, well... one time I tore one up on the trail on a rock, but in fairness I did a lot of other rear end damage at the same time - it was a rough dayThanks for reply but not exactly what I was asking, I likely wasn't clear... Wiring Adaptor connects to the existing 4-flat (which I have on Jeep now) so those wire essentially go directly to the proper prongs on the 7-round (for trailer lights), then the back of the 7-round also includes additional wires that are to be run to and connected to ground, the ebrake controller and the battery for connection to those prongs on the 7-round (ebrakes, aux power). Just wondering if any one has used one of these adaptors and if so what their experience was. Then second question is regarding using an old Brake Controller versus dropping cash on a new on like the P3 that I see number of members have used? Just trying to figure out a good way to get from the 4-flat trailer set-up currently on the JKU to a safe way to haul a pop-up camper for family trip to Utah later this month :thumb:
Mopar actually makes a 7 pin connector kit for the jk. Might be cleaner than cut and splice job
