Well another update here. Turns out this was not my fault. It turns out northridge4x4 sent me sleeves for a dana30 axle by mistake. My nightmare has just begun cause now the axle seal will not fit back into their homes due to the dana 30 sleeve being .75 inches longer then the 44 sleeve. When I was having a hard time gettin the sleeve in and gave it that last good wack, it was hung up on the seals and when the seal pressed out the sleeve went in to far. Well, I pushed the sleeve back out to be lush with the stock axle tunbes like the instructions said to do, and then welded it all up. Now I am really screwed, I have a welded in place sleeve that is to long. Now I have to figure out how to fix this, what a nightmare. Hammer in the sleeves and weld up and your done has turned into a pull the carrior out, get a new axle seal and figure out how to get this sleeve back out after its been welded! Hopefully northridge4x4 comes up with a good solution to fix their mistake.
Moral of this story is check your sleeves before installing them! Don't trust they sent you the correct one.
