Benito
Stating point:
2013 JKUR in commando green
"Mods" installed:
Best top trektop NX
Rugged Ridge hood latches
So it's just about time to finally start a build thread!
First thing on my list is some wheels, which i plan on ordering this week,
Atx Slabs from Northridge!
Then I plan ordering some rubber to wrap those wheels in. I'm trying to decide between Toyo open country mt's or Nitto trail grapplers the price difference between them is negligible but I want either tire in a 37' but I haven't decided on the width... 13.5' Toyo or 12.5 Nitto?
Once I get my wheels and tires I plan on ordering 5.13 gears, and some c gussets ... I know I will need a programmer to fix my speedo, but will I need it to fix anything else since I have a manual transmission?
....then comes the hard part and there is a reason for it, lift!
I am certain that I will end up on coilovers, however in the mean time, before I get my gears and wheels and tires installed I really want to trim as much as I can and run no lift until I can get my coilovers! Is it even possible to run 37's with a lot of trimming and no lift? This is where I would like some input from other members, if it is possible, would I only have to worry about up travel limit? And if it's not possible can I get 37's on there with a budget boost? Maybe 2', just to hold me over till I get my actual lift kit?
Overall build and end goal...still not set in stone but
Suspension:
Evo Double D pro kit, from wha I can see on Northridge and from the thread here about the kit it seems like this is complete and all that is needed is the drive shafts? JE Reel for drive shafts
Armor:
Evo rock skins
Evo rock sliders
Tire carrier:
Stock with extended isolators for a while, but I am really liking the Crawler Concepts body mounted tire carrier
Bumpers:
Trim the stock bumper to clear the 37's
Then move up to a stubby, like the 1/4 pounder with or poison spyder BFH with trail stinger
I plan on leaving the rear plastic bumper, I'm not a fan of the no rear bumper look or any of the options out there. But if I have to lose the rear bumper to clear the tires, maybe go with Evo rear fascia and rear shackle tabs.
Winch: Warn Zeon 10s
I plan on getting a sports cage but I can't decide on which one to go with.
I would like to add but not absolutely necessary:
PSC hydro assist
Poison spyder steel fenders on all four corners.
So that's where I'm at, let's hope it goes my way!
Edit with current build specs:
Wheels and Tires
37" Nitto Trail Grapplers
ATX Slabs
Axles
Dynatrac PR44 w/Prosteer Ball Joints, Reid Knuckles, Ten Factory Axle shafts, Revolution 4.88 Gears, Stock Rubicon Locker
Stock D44 Rear w/Evo Truss, Welded Evo Tracbar Bracket, Ten Factory Axle shafts, Revolution 4.88 Gears, Stock Rubicon Locker, Dynatrac Diff Cover
Steering
PSC Motorsports Hydro Assist Steering Kit
Steer Smarts Tierod
Drive Shafts
J.E. Reel 1350 Front
J.E. Reel 1350 Rear
Suspension
Evo 3" Enforcer w/Fox Performance 2.0 IPF shocks
Evo Rockstar Skids
Synergy Front Adjustable Upper Control Arms
Synergy 3.5" Front Bumpstops (Custom Cut)
Synergy .5" Front Spring Spacer
Synergy 3" Rear Bumpstops
Bumpers/Armor/Rcovery
Evo 1/4 Pounder w/Stinger
Warn Zeon 10S
Evo Rear D-Ring Mounts and Fascia
Crawler Concepts Body Mounted Rear Tire Carrier
Evo Rock Sliders and Skins
Evo Protek Skid System
Crawler Concepts Steel Fenders and Front Inner Fenders
Performance?
Dynomax Quiet Crawler configured to dump before rear axle
Accessories
Trucklite Headlights
SwitchPros Accessory Controller
Rugged Ridge Hood Latches
Bestop Trektop NX
Superchips Flashpaq
