Welcome to Wayalife. Instead of buying smaller tires, why not just re-gear it?
I was thinking about that also, but not sure what gears I should go with.
4 or 6 cylinder? 4 cylinder came with 4.10 gears, 6 came with 3.06 or 3.56 I believe.
If you have the 4 you will need 5.12, the problem is the dana 30 pinion gear will be weak.
If you have the 6 you will be good in the 4.56 range. I'd go straight to 35's with 4.88.
Standing wave from central CA.
He has the 4 cylinder so it looks as though he's got 4:10's as long as it wasn't re-geared be the previous owner
Welcome to the family from Hermosa Beach. Love the YJ!
I had a 92 YJ that I just sold a couple months ago. I loved that thing.
The stock rear axle is most likely the Dana 35. Very weak axle. Look into a Ford 8.8 axle. You can get those in your local pick and pull for cheap. You can even find it with 4.10 and a limited slip and it will match your bolt pattern and width of the front HP Dana 30. The front axle is a pretty strong little guy. I put a Spartan locker in the front and some chromoly shafts and it handled beadlocked 35's all day.
I had 4.56 gears and 35's but I had the 4.0L 6cyl.
Mine also had the bulb problem with the dash. I was lucky and replaced the bulb and it worked. It is a pain to keep pulling the dash apart. Also mine had the cracked manifold. It passed smog with the crack so I just left it after the 2nd one cracked.
Good luck with the build and enjoy!
Wow I didn't think it would pass with a cracked manifold. Thanks for the rear-end info :beer:
First thing I need to do is figure out whats going on with the check engine light. once I get that working I can see if i'll pass smog.
