Rear sway bar end links
Kalums
Very simply I need a set of rear sway bar end links. I got the Evo leveling kit and now my front sway bar is WAY off level. Pm me plz, willing to pay shipping.
let me take a look tomorrow night i might have some. any size?
I'm clueless how should I measure?
I was going to replace my fronts with my rears.... So do I need longer ones in the rear or should I just find another set of stock rears?
For front or rear? You state both in the original post.
Sure folks here will help out and chime in. If you got the EVO leveling king and the EVO links, then you can probably call EVO and ask what they should be set at for that kit. Or call the manu of the leveling kit you got and ask what the links should be set at.
Yes they are still stock, I was going to put my rears to the front and replace my rears. my fronts are about 1.5 inches lower and my rears are off by about 5/8 of an inch, is that what you are asking?
No Evo links
Yes they are, my fronts are about 1.5 inches lower and my rears are off by about 5/8 of an inch, is that what you are asking?
this i can work with, i was thinking of upgrading my fronts because of a Rubicon sway bar, and will have the quick disconnects ones out for the front. as for the rear i just need to check as i have a couple down in the basement after stock and my old ones that just came off as well as the old aftermarket ones off the blue jeep.
That's what I'm doing also I got a steal on a Rubicon swaybar and do not want to put it in till I can either switch my rears to the front or find something else. The short stock ones just aren't going to work as I don't want them to reverse.
I just realised you mentioned a set of quick discos are they for the front only and have you ever seen quick disconnects in the rear?
Yes they are for the front only. There is no need to disconnect your rear sway bar. It would actually make your rig less stable on the trail. The factory rear swaybar doesnt hinder your flex anyway.
Here are my old rears i just took out lol they are a little dirty and need one 3$ busing! As for the fronts i need to take pics of the disconnects are on both jeeps that are coming off.
Ha! wish I had seen this earlier..... Just got a set off one of the guys at work for 10$, literally 1/2 hour ago.... Oh well thx for looking.
