Has anyone ever attempted? I would like to add one without replacing the entire unit.
I used the navtool as well for mine. Works fine but don't like navtool. The have zero support and aren't the best to deal with, but their harness works. The ad said it would disable nav in motion and some other things but it does none of that....just enabled the camera.
I was under impression it doesn't either but it actually does , Press 3 times middle button on the back of the steering wheel , on left hand side
When? Anytime?
i do it anytime, but if you have 6MT like myself you will have to reprogram the interface first, mine didn't work at first I had to load new software which was pretty easy process
I have an AT, but I just ran to the auto store for some brake cleaner and tried it..and sure enough if I hit it 3 times the address field lights up. There wasn't any mention of this in the little documentation I could find. Are there any other known functions or a reference?
i don't use this feature often unless I tow my jet ski, but when vehicle in drive same button press and hold for 3 seconds you get camera while in drive, but I had to rewire my camera to accessory power.
Got the same radio. I used the MYGIG lockpick and wired a camera to it with a license relocation. Works great.
