USMCvet
Banned
I installed my 3.5" Metalcloak lift with Synergy drag link and tie rod. Also, I'm running 37" MT/R's with G2 assemblies with a 5:13 ratio with ARB's. Using a Flashcal everything was programmed and updated. I've had the rig aligned after I finished the install and again 500 miles later. Here's my issues: the JK tends to have a light feel in the steering wheel and wanders a bit - yes the steering wheel is centered, and nothing is loose. Then in the back road sharp turns, the skid control will come on. Now given, I am going a bit fast. So I've turned up the dampening on my Fox ATX steering stabilizer and that helped quite a bit. Also, I'm running the factory PSI in the MT/R's. Your thoughts and expert advise would be appreciated.
