TheDuff
Why are you here? :rolleyes2:
http://wayalife.com/showthread.php?...bye-to-WAYALIFE-sort-of&highlight=combatvetjk
Guess the *wife* didn't get the memo
What do you think about skins?
If u want the best protection, run both the skins and sliders
The whole drilling into the body think makes me nervous, and I'm not really sure that they are needed for anything other then looks.
I think a few of you are misunderstanding what you're seeing. Unlike the old TJ, YJ and CJ before where they essentially had hard rubber hockey puck like body mounts, the JK's come with true isolated body mounts that allow for a considerable amount of movement. This help to absorb things like road noise and provides a significantly more comfortable ride. Having said that, a good set of rocker guards that are bolted or welded to the frame rails don't so much as "flex" into the body but rather, can come into contact with it due to the considerable movement the body mounts allow for. It takes a big hit for this to happen but, the same is true of a big hit to a rear bumper. Sliders that attach to the body alone are nice and worked great on TJ's but, on a JK with it's paper thin sheet metal, I have seen where this can and will lead to buckling of the body. Sliders that attach to the body and frame don't work well either and tend to be noisy due to the fact that body mounts allow for too much movement. Of all the solutions I have tested and seen, frame mounted rocker guards are still the best option and are what I prefer to run.
Someone had their slider flex into their rocker recently. The skin protected the body from damage. Moreover rocker skins protect from the what ifs, they are also aesthetically pleasing![]()
For the most part, they are more for looks than anything but, I will say that I have hit mine at the B-pillar and they did help to protect it. FWIW, Moochie doesn't run any skins and he's been fine.
Drilling into the body is hard to do but it's not as bad as you would think. After the first hole, it's all gravy![]()
You all going with steel or aluminum?
I went with steel.
Im thinkin thats the route im going. northridge says it comes powdercoated?
As Jags stated above, it's tough taking the plunge when drilling that first hole, but keep in mind, drilling holes in your jeep means that your jeep is evolving!
I can understand the hesitation if you weren't in it for the long haul and someday would want to sell or trade in your jk. However, if you're like me and plan on keeping you jeep for as long as possible then drilling holes is a great first step in getting comfortable with modifying your jk to improve its performance. In the end, the choice is yours, but here's some holes I've made in my hood and the outcomes:
Holes made on my hood for PSC hood louverView attachment 51161View attachment 51162View attachment 51163
After cutting up the hood, I started doing everything else and I did it without hesitation. I cut holes in the rocker panel and rear quarter panels like a hot knife through butter
