Accessing Dash Cigarette Lighter/Power Port Hole
RUBINOT
I'm wanting to replace that useless clip holder on the lower right center dash area with a USB power port in my 2014 JK.
Is there any tricks or short cuts to installing this power port with out removing the upper dash assembly or is removing the upper dash the only way.
That's where I put the switch for my daylighters, I just popped the "glove box" out reached in behind and pushed that whole little panel out. popped the little clip/holder thing out,and reassembled in reverse. (after mounting my switch of course)
Used two washers, painted the outer one, fill that stupid factory weird shaped hole for the dumb factory "shopping bag hook". Then sandwiched them between front on rear of panel. Then installed USB power port.
a friend had some matching plastic (i for get the name of it) we cut it out filled the whole in with it then cut out the new whole for a heated seat switch.
I dont have a pic of the circle we cut out but its on the jeep floor on the right.
What USB port did you use?
Looks good. :thumb:
