Fixing the fender...
jorgelrod
I hit a Durango brake light with my fender and it broke the inner rib which I replaced this weekend, the only thing that is left is the flare itself that got some scars from the accident, is there anyway to clean this up a bit??
You can sand it lightly to remove the excess plastic that it peeling up. That's about it though. The scratches are more of a sign of use.
Use a dremel maybe and carefully grind off the plastic or just use a sander and sand it down. and repaint. However.. I recommend the fender cut!!
