GM13 - Loose bolts? I don't got no stinking loose bolts! Lol.
BitBucket - I made the AL plates out of some scrap in my garage. For some reason I envisioned the bolt heads eventually cracking the hard top. I made the plates to evenly distribute the pressure. So you have these bottom plates too? What year is your JK?
Ever think maybe it was the plates that you added that is causing the issue?
I just recently added the AL on top, bottom spacers have been moving outward since new. I just move them back every so often. I'm mostly interested in whether they are supposed to be there in the first place. Maybe they should have been removed during dealer prep?
I replaced the bolts.I'm surprised your bolts are long enough with those aluminum plates you added. I tried to keep my tuffy security deck in with the hardtop and the bolts weren't long enough so I just run it with the soft top. I need to pick up some longer bolts.
