desertrunner
Trying to drill the hole into the coil pocket on the drivers side for the sway bar link bracket and when the bracket is flush up against the stock sway bar link tab the top right hole that I need to drill for comes in contact with my C gusset and pushes it forward a little. But when I put the bracket flush against the coil pocket it tucks around the C gusset no problem. I'm pretty sure I read the directions right in understanding the bracket should be flush against the axle tab and use that little spacer in between the coil pocket and the bracket? If that is right should I grind a little off the bracket to make it sit straight up and down when it contacts my C gusset?
![ForumRunner_20150319_072243.png ForumRunner_20150319_072243.png](https://www.wayalife.com/data/attachments/109/109225-80d0999742da47be6cf6eb56536b6940.jpg)
![ForumRunner_20150319_072254.png ForumRunner_20150319_072254.png](https://www.wayalife.com/data/attachments/109/109237-72bf43b42fe66a803ecc95f013630a3e.jpg)
