On an 09 jk, is a 3inch the biggest lift without swapping driveshafts?
Front for sure, I ripped my boot first time out. Rear is going to need to be done, but you might get a little bit out of it. Mines an 07 2 dr auto.
A ripped boot doesn't mean the driveshaft is trash.
OP you will need both driveshafts eventually on a two door. I had to replace my rear before I had to replace my front.
It isn't trashed "yet" but it will lead to a failure. Just wanted to clarify
Fair enough, not trashed but you'll want to plan on replacing sooner. It doesn't explode your jeep, but it makes a terrible noise until trim it up underneath.
The noise is the CV. Excessive wear is caused because of the angle.
