I got the Evo underhood compressor mount and looks like I need to move the horn, where is the easiest/most common place to put it?
You shouldn't have to move the horn. :idontknow:
Yup horn is in the way. That's why I mounted mine under the front passenger seat.
Edit: just realized that you are talking about the horn, not the compressor.
This would be too funny to do tho
Have this setup on my 14. I just mounted the horn on a corner of the compressor mount using the stud on the side of the horn. I'll take a picture later tonight.
That thought has occured to me.
How did you go about mounting the compressor to the bracket? The write-up says to have the bolts going from the bottom up - but they seem too long to do that. They make contact with the body of the ARB.
But if they go from the top down, they contact the brake thing on the firewall so the mount doesnt sit quite right. :doh:
Had to cut the bolts to fit. I installed them from the top and trimmed the 2 rear bolts.
he has a 2014 they have a second horn there just move it out the way and install after the arb is in!
Learn something new everyday. Does the second horn make the weak-ass one my 2012 came with sound decent?
Most likely it's still sounds weak :cheesy:
