OverlanderJK
Resident Smartass
I rubbed it off with my hands
Not surprised.
Not surprised.
Not surprised.
I think you and I are talking about completely different worlds in terms of use.
Yes a slight rub from some dirt and you could peel off the plastidip and do it again and no one would ever know...but that wouldn't damage/scratch off bedliner either.
Hit a boulder with your plastidip and it can't be touched up to cover a deep gouge. Bed liner won't fill the gouge either, but it can be touched up. The ONLY benefit from plastidip there is, is that it's reversible back to stock.
OK.... what I'm saying is....
Scratch a painted wheel and you'll just have a scratch.
Scratch a plastidipped wheel and it'll tear and rip across the wheel.
If you really wheel and abuse your jeep....then plastidip is silly and will require constant removal and redoing. Scratch paint and you only have to perform a 5 second TouchUp. Why do you not EVER hear of or see a truly used of road vehicle with plastidipped wheels? Why are rock rails nit covered with the crap? Because its dumb to waste your time and energy constantly fixing it. That's all I'm saying.
Here's my stock plasti dip wheels. I tried to give it a fake beadlock look. I used blue painters tape on the edge cut in small pieces to get a even edge. Looks good from a distance but up close not so good. I also used the glossifier so it wouldn't be so flat black looking. Also kept the center cap and lugs unpainted.
Thats a pretty bad tape line....I bet your mistake was peeling the tape after the plastidip dried. If you want sharp lines, you need to peel it while it's still wet, and if you use blue tape, you need to use the edgelock tape, not the regular one.
Yup. That's what happened. It was just tearing when I went to pull off the tape. I thinking of just making it all black. Should i peal off what's on there and start over? Or just clean it and spray on top of what's there?
