cozdude
Guy with a Red 2-Door
Hey everyone! I could really use your help right now.
I'm currently trying to install new u joints and new outer shafts onto my inner chromoly shafts that I ordered with my ProRock 44. I was able to install the u joint onto the inner shaft super easy but when it came to the outer it was a different story.
The u joint caps are not going into the outer shafts easy like they did for the inners. The outer shaft I ordered was a G2 non-rubi 30 spline shaft which is stock. I ordered this outer shaft because I was told that I would be able to run the current ten factory outer shaft I currently have installed in my d30. Instead of breaking the current shaft down I figured it would be easier to sell the whole shaft as is and get new outers.
Did I mess up and order the wrong outer shaft? Should I have ordered a 44 outer shaft with a 30 spline count?
Here are pics of the part numbers I ordered and what everything currently looks like.
Inner shaft and u joint with c clips installed
New outer shaft semi installed with not flush caps.
.Inner shaft and u joint with c clips installed
.New outer shaft semi installed with not flush caps.
