Regnar
I'm sure these questions have been answered before but I'm having trouble digging through to find em.  I have 37 inch tire with a 4.5 inch AEV lift and bushwacker flat fender flares.  I've also had a rubicon front drive shaft installed for the angle. After I installed a Smittybilt rear Atlas bumper my rear end is sagging a little lower then the front end.  A 3/4 inch spacer over the coil springs was recommended to level it out. I'm also rubbing the front area of the wheel well towards the pinch seem.  Is the spacer the answer or is there something wrong with my suspension? Does something need to be adjusted? Would I be better suited running 35's with this lift instead of 37's to prevent the rubbing?  Any suggestions will be appreciated.  I have most the stats on my jeep in my profile.
Thanks
Reg
			Thanks
Reg
