Breakline question
leaky10
It's time to replace my stock rubicon tires. I'm doing a 2.5 lift to clear 35's. I've pieced it together from parts off my old Jk. The only thing I'm missing are the break line drop bracket. Can I run without those until I can pick up a pair? I will not be wheeling until I have them.
yea you should be fine. as you mentioned the only time you would see an issue is if you flex it out or take it on the trail
When I put my 3 inch plush rides on I went with Crown Performance 4-6 brake lines just so I would
Not have to do it again when I upgrade to coilovers later on. Well worth the $150 to know I do not have to install new brake lines.
Yes I agree Crown would be a nice choice.
like others have said, longer brake lines would be the best option.
What I don't like about drop brackets is they move the brake line metal tubing down making it more susceptible to wear and damage.
