I'm just curious how others are running power to their goodies... I have seen the switch panel that mounts in the area in front of the shifter, and an a pilar mount but I'm curious about any more "custom" solutionsI did stereo installs back about 20 years ago and we did some pretty cool things with power distribution. Just curious how others are doing it... I am not a big fan of having 30 different wires coming off the battery
I want to take a large gauge wire to a central point and run the items from there.
-J
I use an sPOD, works great. There are similar companies building similar products though.
I added a terminal strip on my Fj under the dash for power and ground. so I had one power wire from battery and one ground wire from frame to the strip. then jumper each terminal with power and ground as needed... if that makes sense:thinking: I wish I had the pic's for it. It worked out great.
Where did you mount you spod?
-Jason
The sPOD switches are mounted between your visors
Any pics of the Spod?
So I work with Helicopters everyday and I have been kicking around the idea of using the pull out circuit breakers for my "extra" electronics, lights, and such... I'm gonna try to have a panel etched to mimic the Helo with labels for what each breaker is for... Now, where to mount it??
-Jason
With sPOD, I am just wondering about the big cable like your winch or power converter, would it deal with that type of cable?
