When I went for the AEV 2.5 dualsport lift here in Europe I was looking for moderate lift (no Pucks:those stink), firmness, road and trail handling. I wanted 33 tires (285x70r17) on Pintler beadlocks and good all around use (no mall crawling there are none around here:rolleyes2
I have to say that I found exactly what was intended. Firmer handling on road - Not harsh - european standards/speed (very often 80+ mph on highways) and mountain roads. Good handling off road on fast trails and moderately rocky and steep mountain trails. I don't run the Brackets because the caster angle isn't dramatically off and the diesel 2.8 is heavier than the V6 3.6 loading the springs a bit more.......(however the AEV Brackets are intended for their kits and it is much more logical to run AEV Brackets on a AEV kit than Rancho's do it all/do it wrong kit).
the only gripe I have is the brackets for the front swaybar links which are stupid....AEV should have supplied longer swaybar links.
PS: I added Northridge's grade 8 bolt kit (not for the Grade 8 but for the mechanical logic of it (even though its a pain having metric and SAE bolts) I'm putting disco's in front and will certainly upgrade the brake lines to longer braided steel type lines.
