mstrofpuppets
Ok here is my problem, I have a 2011 JKUR with a 2.5" RK max travel lift running stock bump stops and stock tires. I am running Fox IFP shocks for 1.5"-3.5" lift and they are the ones with 9.1" of travel and measure 24.75" fully extended. When my Jeep is sitting level I have 4.5" of shock shaft exposed and a distance of 6.5" between my stock bump stops. I really want to add the rock stars that I have in my garage but I do not believe my shocks will work because they will over compress before my axle contacts my stock bump stops. Looking for clarification, in order to run the rock stars I either need to run 3"+ of bump stop or run a stock length shock? I also plan to run 35s in a few months. Any body running this set up with rock stars? Any help would be awesome!
2011 JKUR, manual trans and some other stuff.....
