bkac
I installed my EVO bolt on coilovers and need some help with dialing them in. Here's what I have and where I'm at.
I currently am running 35s on 4 door with LoD rear bumper/carrier with a spare, EVO 1/4 pounder with stinger and no winch, I have LoD sliders, and protek skids. So that's basically my weight. I'm running a coast 1350 front ds.
So the fronts are set at 1" on the top collar.
The rears are set at 1/8 inch down on the top collar and the silver trim rings are set at 3/4" from the slider,in rear at ride height.
In the front I'm sitting at about 3.5 inches of lift and the rear seems like around 4. I can't seem to get the rears much lower.
I called EVO not ORE on Friday to ask where to set my slider trim rings and Andrew from EVO said about a thumbs distance from the sliders at ride height. I have no problem doing that on the rears but the fronts, i can't get close to that because i run out of threads on the shocks about 2.5 inches before I get to the slider. So how should I set up the fronts and rears?
Since i have installed them I now have a slight roar/vibration above 60mph. It's odd because i didn't change lift height from my 3" enforcer. Any thoughts on this would really help.
Can i get driveline vibration from a factory rear shaft with 3.75-4" of lift? I'm running factory arms in the rear and evo lower fronts.
Thanks for the advice :thumbup:
