Mikead40
So a few months ago I changed out my rear diff fluid and cleaned the gears etc with brake cleaner. It looked like this
I reseated the stock cover with rtv and filled it with royal purple. Good to go.
Last weekend I noticed a small drop of fluid on the bottom of the diff cover - and on closer inspection the bottom lip of my cover was bent back very slightly.
Other than that it was working fine - no excessive noise, slippage etc. Today I took off the cover (it still had plenty of gear oil in it) cleaned with brake cleaner and it looked like this
My question(s) - I'm assuming that reddish brown stuff is rust, however it seems to rub off easier than I would expect rust to. Is there any possibility it's something other than rust? Has anyone seen this before, and do I need to be concerned about it? I'm waiting on ups to deliver my new diff cover, so it's currently sitting in my garage with the diff cover off. Is there anything I should do before installing the new cover and filling with gear oil? I plan on using The Right Stuff instead of regular rtv this time.
Any advice would be really helpful - thanks.
.I reseated the stock cover with rtv and filled it with royal purple. Good to go.
