Coming along slowly. I'm not great on write ups. But I will do a segment on here to get the 14 bolt together.
Everything pulled apart and shaved. Just waiting on a couple things then back to work.
looking good! yea keep us posted with pics and please do the best you can on a write up. im sure there are some people here (or out there peeking in) who would want to build a buggy or something and want to use a 14 bolt or d60 to get the job done :yup:
The corporate 14 is the easy one to swap into the jk. artecindustries.com makes a kit with all the brackets to wield on. You can get a set of tone rings from VKS fab and press them onto the hubs. There are several companys that sell a rear brake kit to turn the drum into a disc brake with E-brake set up for around 500.00.
Found time to shave the 14.
Now just need to get the brackets and wield it up!!!
Looks good! Question, was it necessary to shave the 14 bolt or was it just so you could use that diff cover?
ballistic fab sells the standard diff cover. It is not necessary to shave the 14. I did it for ground clearance. With it shaved i'm only (roughly) 1/8-1/4 inch difference than a Dana 44 on ground clearance. So the 14 is way stronger than the 60 and now has the ground clearance of the 44. :icon_crazy:
it is not cheap to shave a 14 though. the kit is 240.00 (if I remember right) the ring gear has to be ground down now, that's 100.00 and the rod to wield it up is a special rod. due to it being cast iron.
Interesting. Learned something new. Thanks!
I thought 80's were generally considered a lot stronger than 14's, and that there are a lot more gear choices. :thinking: (Obviously I know the price difference is significant)
I bet you are glad you choose the 80 for your jeep SharkeyTechnically the 14b is considered a 70, but what do I know since I spent almost that much building a 44 for my tj
Good job on your buggy Ricky!
