And do I need thisView attachment 96878View attachment 96878
Sent from my SM-N900W8 using WAYALIFE mobile app
Wondering about those washers also. What about the t case?
I didn't use the large washers :idontknow: your stock t case skid is all you need it bolts back down onto the cross member skid :yup:
Me either, i think they might go on top of the transmission mount bolts. Idk... Left mine out too.
I think you are correct, I didn't see it mentioned in the project JK write up http://project-jk.com/jeep-jk-write-ups/evo-mfg-protek-skid-system-for-2012-jk
Yeah, i read that a few times before i did the install. Maybe we have the deluxe kit.
Btw, does your center skid touch the rear of the transmission pan? I have an auto tranny.
No it don't touch, I have auto trans also, you did put it on top of the trans mount right? You only jack the trans up to get it in place, then it bolts to the trans mount on top, not in between the trans & crossmember just to be clear because I was a little confused on that part at first
It goes on top of the rubber isolator. But how much can you lift that transfer case? and is it safe?
Here are my pictures...
it should be on the bottom with this bracket over the top
