I just got 513s installed in my 14 JKR Automatic last week...
At 65mph - I'm at 3000 rpms - is this a normal range for running 315/70r17 Duratracs.
- Slabs and 37" Toyos get installed on Friday
based off the chart in the noobie FAQ, yes it is right
Yeah I've looked at that but wanted to double check since people raved about getting their mpgs/Eco back once they regeared - both of which have shit the bed for me since the regear.
I think I cruise at about 75 and 3k? Thats with the 3.6, 5.13, and 37s on slabs @ 30psi.
Gas mileage, mixed driving over 5 tanks was about 13.6 mpg. Long drives on the freeway with minimal traffic at 75 is around 18mpg, at 80 its closer to 16. But its all variable.
500 mile drive into a strong headwind I averaged 10.5 mpg, same drive in reverse with no wind was 16.
Is it sad that I'm on 35's with 3.6 liter and 3.73 gears and I have waaaaay worse milage! Lol
No. You would - 4.56 is good for you. Thats what ill be getting!
Yup...
4.56 if you never plan to ever go over 35's and want the ability to go back to stock without super high RPM's when you do at highway speeds.
4.88 if you think it's at all possible that you'll eventually go 37's
Typically, I would recommend 5.13's with a set of 37" tires and that would put your RPM's at about 3k when running more like 70+MPH. Being that you are most likely running something closer to a small 37 or big 35, yeah, that sounds about right depending on what your tires actually measure out to.
Thanks Eddie.
My slabs and 37s were installed yesterday so I'm back to a normal rpm range!
