What wheels? 4" Evo Enforcer lift with 37in toyos.
GregMort13
Hey guys. Having a hard time deciding what wheels i can use with my 37x13.5r17 toyo open country mts. Just a little background, I've got a 13 jkur 10a. Manual trans. Gonna roll with the stock gears (4.10) until my warranty is up in a little. Just a little info to help.
4" Evo enforcer (37in tire setup)
Drag Link flip
Bilstein 5100s
Looking into getting...
1350 Front DS
C Gussets
Rear adjustable control arms?
Was mainly looking for advice on backspacing and rim width to use with the wider tire.
I prefer beadlocks as ill be visiting Rausch Creek often, but i honestly don't plan on beating on her too hard. My two options in mind are...
17x9 ATX Slabs
17x8.5 Fuel Trophy (Non-Beadlock)
If anyone spots a problem with my intended setup please voice your opinion. Any advice is appreciated, thanks guys
I'd go with the slabs for a 13.5" tire. And did you already have front lower control arms?
I run ATX Slabs with 37x12.5x17 Nittos. The Slabs have 3.5" backspacing and no need for spaces with my tires. I will guess that 13.5's would be fine as well with that backspace. If you go with more backspace - spacers will be needed.
Thanks for all the advice guys. I do like the atx's. The slabs have 3.5"backspacing and the chambers have 4.5 i believe. Not sure which i would be better off with as i don't know much about backspacing.
A easy way to look at backspacing is the smaller the number the further away the inside of your tire is away from the frame.
I installed the Enforcer this past weekend on 4.5 atx's. I really wish now i would have done the slabs. Hind sight is always 20/20. I personally would at least find something with 4.0 BS. Just my 2 cents. If you can swing it go slabs. You won't regret it at all.
sent to you from sunny central Oregon!
Allied monster beadlocks...been running them for years. NO leaks. Check Pirate think I saw a set of 5 for sale.
You may have to adjust your steer stops with 13.5" tires and 4.5" back spacing to avoid rubbing on turns. The fuel is a skinny rim for that size tire also. The slabs would probably be your best bet with that particular tire.
Ok, just re read, do you have a aftermarket rear drive shaft? If so then the rear uppers are needed. But if you are running a rear factory shaft the factory uppers are fine.
chamber pros have 4" of backspacing
I am really grateful for all of your guys inputs. I went straight to the head of the horse and talked to jake at off-road evolution. He explained to me that i would be fine with either the slabs or the chambers. Both of the backspacing for them two choices will work with no rubbing. I don't need rear upper control arms because i have the factory rear driveshaft. I like the chambers because of the extra clearance due to backspacing (thank you for explaining that to me) but i like the slab special. I guess its a win win haha
Double post oops.
But i just realized the slabs are the win win. I mixed up the backspacing between the two rims.
if you like the chamber pros more than slabs you can get them for virtually the same price. if you use the 10% discount from northridge it comes out to only $30 more than the slab special. just something to think about.
after seeing yours and eddies chamber pro's, I'm really wanting these for our white jeep now. they really do look nice!
You guys are killing me haha i cant decide
in all honesty it comes down to which wheel you think looks better. they both do the same thing and both made by the same company so you know the quality is top knotch.
i went with the chamber pro's because of state regualations saying that i cant have to much tire sticking out. also when i move up to a 13.5" wide mud grappler its not going to stick out as far as it would with the slabs. just something to think about. i have pics on my build thread for how far it sticks out now with a 12.5" wide tire if you wanna look
