EVO Enforcer 3" where and what to buy?
bkac
I'm going to purchase a 3" EVO Enforcer tomorrow for my 14 JKUR. I was wondering where I should buy it from. I don't think Northridge allows the 10% off on EVO. Are they still the best place to buy this from? Also, I'm going to get the draglink flip. Do I need anything else? New Trackbars etc? Should I go with a procal or something else?
I need help on which shocks to go with too!
Thanks in advance for the advice. :D
Sent from my SCH-I925 using WAYALIFE mobile app
Probably a front drive shaft. I'm not sure what collapsed length shocks you are going to need, but I'd get some Rancho shocks. What size tire are you going to run? You will need at least 3" bump stops for a drag link flip.your factory track bars are fine because you are going to be running raised track bar bracket front and rear. That's about it, pretty simple kit, every thing you need is in there and nothing you don't.
I can't tell, but are you going to run flat fenders? If so I'd get the 3" bump stops.
You use the stock trackbars with axle side relocation brackets included in the kit. You should get a new front driveshaft and also move your EVAP over a bit in the rear so it doesn't tear the boot on your rear shaft.
I'm a big fan of the King 2.5's but if you don't want to spend that kind of money, maybe Rancho 9000's or Bilsteins. I've never driven those shocks (Rancho or Bilsteins) with EVO's plush ride coils though, so I can't vouch for the combo.
I'm running 35 duratracs and factory fenders. I don't have plans of flat fenders anytime soon. Maybe one day with 37's. That's a ways out...
Thanks for the info. I will get a front shaft while I'm at it. Where/who should I buy all this from?
