BrandonDetrick
Thats what I figured. Do you know anyone who runs the evolever on a two door ? Cuz I know vengeance's setup was custom
So can the evo lever be upgraded from a single coilover to the dtd or do you have to just begin with the dtd serup
And Evo will let me order everything separate as I get ready for the different stages working up to dtd all around
This is in my build plan as well. At this time I'm running the EVO enforcer and will be working my way up to DTD status.
@WOL what would your comparisons be as far as running the single coilovers and then upgrading by adding the triple bypasses? What were the differences both on and Offroad?
Will the bypass shock lessen my rock crawling ability ? Cuz I know Moby evo1 and everyone run dtd and still crawl awesome
That's what I thought. Do they come tuned already or do you have to tune the bypass shock
Had single ORE coilovers and 35" tires. Could barely fit in garage. Wanted to go to 37" tires, but
concerned about garage clearance. Talked to Mel. He said DTD front sits lower because towers
slanted back more. So....got DTD and 37" tires, and I can fit in garage. Advantages, can run
faster in desert over bumps and have lower center of gravity.
Hmmmmm that concerns me:shock: I am/was looking hard at the Enforcer using Bilsteins VS. The front and back bolt on coil over kits...on 35's
Enforcer on 35's how tall?
Front and back bolt on coil kits how tall?
Donny
I dont see how you would have any problems fitting in a standard 7' garage on a enforcer lift and 35's or 37's for that matter.Hmmmmm that concerns me:shock: I am/was looking hard at the Enforcer using Bilsteins VS. The front and back bolt on coil over kits...on 35's
Donny
FoxC said:I dont see how you would have any problems fitting in a standard 7' garage on a enforcer lift and 35's or 37's for that matter.
Great info! :thumb: Now if I can find away to afford this on a new white 10th annivosory Rubi I'd be super happy girl! :yup: But may run into the problem of never wanting to leave the Jeep. Lol
