RUBINOT
I recently installed a Rugged Ridge Pillar Pod with their four switches. Everything works fine.
However when I turn off the switch's one of the switch power light dims to off rather than just turn off.
It's also the only switch at this point wired to a accessory, my CB. CB works great.
The switches are piggy backed wired for ground and power. Switches have good ground to body and cb is grounded seperately.
Main wire is wired to battery with in line fuse.
Is this dimming to power off a issue or not and if so would be causing it.
Sent from my SPH-L710 using WAYALIFE mobile app
