Hi from the UK
After running 33's for 2 1/2 years I'm serious about upgrading to 35's on my 2 door JK. It's more to do with looks than function - 35's look badass.
I want to do this on a budget as I've spent way too much on the Jeep in the last 3 months on doors, lights, tyre carrier, etc.
I need some help on what I need to do and if possible links to the equipment I need to buy from the likes of Teraflex, and other decent companies.
My vehicle in stock form is a 2 door 2011/12 Sahara with a 2 1/2 inch Terraflex spring lift with shock extensions. Tyres are Mickey Thompson 285/70/R17 Baja MTZ. They're about an inch past the fender so I'd be looking to correct this. Also I don't want to have to chop or replace the fenders.
Tyres
The Mickey Thompson tyres I currently have are expensive at £230 each ($390). So, I would be interested in a cheaper aggressive mud tyre as I have to multiple this by 5 and I think I could possibly save several hundred £££'s here. They need to be good for the road though. What do you recommend? No all terrains please.
Axles
As this is the Sahara model will I need some axle strengthening? What are my options here and if you don't mind can you point me in the right direction of manufacturers parts.The only off roading I do is with the UK Jeep Owners Club three or four times a year and is mainly mud based, apart from that I stay on the tarmac.
Gears
Mine's an auto on standard gears, will this be OK or do I have to consider re-gearing.
I have the AEV Procal already, so no need to purchase that.
I have a Terraflex tire carrier and hinge on its way from Quadratec.
Is there anything else I've missed. Any advice is appreciated as I need to work out the total cost
Paul
Tyres
Axles
Gears
Paul
