Tranny fluid leak? Omg!!
Is it a redish color (tranny fluid)? Are you sure it's not gear oil coming out of you diff breather? When it comes out it will blow back and coat other parts of your Jeep. It looks like your hose is hanging down to low.
Yup it's a purpleish color and a lil clear but it's just under the tranny lots and lots of fluid :/ I just clean all that crap out and I'm waiting to leak again and check
Do you use Royal Purple oil?
Yup I used royal P
If I can't find the problem by 12pm I'm taking it to my buddy's shop
You just did a oil change correct. Looks like leaking around the oil filter. You sure you snugged it up right?
I always had that old gunky oil by the filter it's like grease lol
And oil level is perfect
Coolant is like always and the tranny fluid is on hot. So I don't know what to check now
If he did an oild change it could be that or if he put two seals on (left the old one on)? How is the oil level might just want to check that as well!
Nope lol that happened to me one time only hahaha now I always check my filter seals :)
So it's clear and not red? Probably just a oil leak from around the filter area, looks wet there and running across the bottom of your block. Synthetic oil is good at finding little cracks and leaking out. You sure you put oil on the filter o ring and tightened it up right?
If all of your fluids are up to level then that means something got over filled and is blowing out the extra. Check around the dipstick. (Not you, the oil dipstick).
