tonytony9
Dear Forums,
It's that time of year again; time to bring out the hard tops. Instead of dropping a fortune on a hardtop lift system I created my own for little under $20.00 and a quick trip to my local hardware store.
Many probably already do this or know about it, however, I thought I could share my own personal system/experience.
As you can see from the picture my system is pretty self explanatory.
First buy yourself a set of these:
I got a four for only $17.00 - Hold up to 1200 pounds I believe.
If you have rafters in your garage then buy some sort of hooks (got mine from an old swing set) in order to hook the ends of the straps onto.
Simply open the back window, wrap the straps around and begin to lift your roof. It is pretty self explanatory and in a way unique to your own garage. Hope this helps someone out though!
Question: Is the system which I am using harmful to the hard top in anyway? I have it evenly balanced and it is only holding its only weight. I just want to make sure it won't cause any significant damage.
Thanks,
Tony
Thanks,
Tony
