Implausable left wheel distance signal recived
Prime
It's changed out my hubs and I threw this code. Thinking it maybe a bad sensor I took off one of my old ones and still the same. Could it be I got a bad new hub?
no dirt or grease on the sensor? it's possible to get a bad unit
I would start by checking all of the sensor wires. I have had a couple if issues with the same code but it is always accompanied by a second code for the sensor not reading. The first time this happened I I sucked a rock up into the wheel well and it took out the wire in the process. The next time was a bad soldering job on the fix the first time. Hope this helps
From the research I have done I think it could be the rear left sensor. Didn't know the rear had abs speed sensor, my code said the left side I replaced the wire from the new unit but still threw the code.
