jeff_in_rc
I have always wanted a better way of putting the gas I carry into my Jeep without having to loosen my spare to get my jerry can out and thought, what about an electric fuel pump? No more lifting the can, spilling some and smelling like gas for the rest of the day. Not to mention those damned C.A.R.B. compliant gas cans they sell now in the wonderful state of California. What a giant PITA!!
So I got to thinking, how could I use the power connector for the hard top my Jeep used to have? That started a search for the 6 pin male connector I would need. Well after calling/emailing several Jeep junkyards I had a real problem paying $75.00 for a used OEM harness that I would have to cut up. I had found on one of the many Jeep boards I belong to a wiring diagram for the power connector so I was part way there.
I finally got to go to a small local junkyard and after explaining what I needed he sent me out with an employee in tow. We looked over several Dodge Caravans and some older Jeeps to no avail but then while looking over a Dodge Durango I found the exact connector I needed, hell it even had a cap on it so the connectors were perfectly clean, sweet! So I cut off a pair of connectors, paid my $30.00 and was on my way.
Stopped by O’Reilly Auto Parts and picked up a high volume electric fuel pump, 10’ of fuel hose, a toggle switch, and a set of hose clamps. Then I stopped off at Home Depot and picked up a small tool bag to put everything in. Got home and verified I had my power and ground on the proper pins and wired up the switch and pump. Installed the pump on a piece of wood I had, cut the fuel hose to length and tested my setup by pumping the last 2 gallons out of one of the jerry cans.
Well it worked perfectly and the pump is very quiet, hardly makes any noise at all. Now if I go on longer trips where I need extra fuel it will be simple to re-fuel my Jeep without have to pick up any of the cans.
In case you need it here is the wiring pin out for the 6 pin female connector in the tub:
1) Black with white stripe - 12 VDC for defroster
2) UNUSED
3) Brown with green stripe – 12 VDC for wiper
4) Brown with pink stripe – Wiper Park
5) Brown with pink stripe – Wiper Park
6) Black – ground
For the male connector I got:
1) Red - 12 VDC for defroster
2) Violet with red - UNUSED
3) Tan – 12 VDC for wiper
4) Black with yellow stripe – Wiper Park
5) UNUSED
6) Black – ground
The first pic is of the tub connector, the second pic is of the tub connector and the pump, and the third is of the basic setup when in use. So I have $30 for the junkyard find, $60 for the pump and hose and $10 for the tool bag for a total of $100, not too bad in my book and I am sure some of you can find parts cheaper but hey, I live in a small isolated desert community.
So there you have it, what do you think?
2) UNUSED
6) Black – ground
5) UNUSED
6) Black – ground
