jkjurny
So I'm getting ready to wire this up, and have been reading a lot on the Internet on the different ways to make this happen. This is what I've come up with, but want to see if it is wrong or if there is another/better way.
Switch = SPDT Switch
Relay = Standard 30 AMP Relay
Lights = Poison Spyder LED reverse lights
So for constant on, this is simple. Wire fused source to switch. Run On output directly to the reverse lights.
Here is where I'm stuck, but think I have figured out.
For on with reverse lights.
Run from SPDT switch to pin 30 on relay. Splice reverse light power into 86 on Relay. 85 to ground, 87 to Reverse lights. Is that right? With this setup, should I add a diode between the relay and light, and also between the light and switch for constant on?
Thanks.
Thanks.
