Eddie,
I know what suspension system Moby has, but am curious as to what the actual lift over stock is with that setup.
Tagging on to that question... My EVO Enforcer is rated for either 35 or 37 but could I run 40s with flat fenders? I am aware I would lose some up travel compared to moby
Thanks!!
It's really hard to get a perception of size from pictures!
it is. i'll have to find a shot of moby next to a rig with 37's and you'll be able to see it better.
RockIt Man said:Tagging on to that question... My EVO Enforcer is rated for either 35 or 37 but could I run 40s with flat fenders? I am aware I would lose some up travel compared to moby
I wouldn't do it. I've trimmed a lot of mine rear pinch seems already and just saw this the other day. Time to trim the front I guess. This is hitting with 37s.
The Enforcer has great flex. I wouldn't want to limit it just to get some 40s under it.
MTG said:Moby looks huge!
Part of this is the angle of the shot, but I'm on a 4" lift and 37s.
<img src="http://wayalife.com/attachment.php?attachmentid=7479"/>
bdmckenna said:You still have pinch seams?
OverlanderJK said:Another Moby question but not the same as the first.
Where are the rock lights on moby mounted? I looked on project jk but only found where the fronts are mounted. I also couldn't really see a good spot to mount them under my jeep so I was curious where his mid and rear rock lights are.
I believe the rear light on Moby is mounted on the parking brake cable bolt.
JK Factory Fender ChopEddie, I see that you cut your own fenders. Do you have a template? Or is it your own personal touch? Got any advice for a newb? I have a Dremel and Sawsall.
yup, we have one light attached there and have side lights attached to bolts that were originally used for the rubicon rocker guards. i would take and post up pics but, moby is still at off road evolution. :grayno:
I'll bump this question up later when Moby returns. What's he getting now?
