Death Wobble - This is the best thread I have seen.  It helped me fix mine.
First off,  thanks for sharing this insightful knowledge about resolving and providing an understanding of the death wobble issue.   Without this direction I would have spent thousands at a shop to get it fixed.
I have a 2006 Jeep Wrangler TJ.  It has 33" tires, 4" suspension lift and a 1.25" body lift.  I use it for light trails occasionally getting a little wild.  I hit the mud pit once,  first and last time as clean up was a bear and you can't see whats under the mud.
So,  at some point at 40-50 the death wobble started.   I believe it was after mudding and hitting a hole that jacked my alignment up,  and so I had the dealer re-align.  Still the death wobble.   Now,  when I say death wobble it is the wobble that violently shakes from the front of the vehicle to the back so much so that my rear shock mount ripped off the rear axle,  there was no powering through it that time.  I have powered through 40-50 to get me home but it's sketchy to say the least.
So,  this thread listed check the track bar and look for anything shiny on the front suspension.   Sure enough,  the lift kit has this drop mount of the driver side frame for the track bar to connect to,  it looked solid, but there was shiny metal on the outside where the sway bar is.
I had my son turn the steering wheel left and right, and sure enough the 3 bolts while super tight,  there was play about 1/4" in the track bar.   Easy fix was to weld it to the frame.   By the way,  first pass was to weld the rear bracket to the frame as well which reduced the wobble from 100% to 85%,  no longer tearing off shock mounts.   After welding the front mount onto the frame the death wobble reduced to 15% of a death wobble,  I will call it a slight wobble coming from the front right manifesting the feel in the steering wheel.      The next approach was to change to a slightly toe out alignment,
which made the 15% or even 10% wobble go to 0% wobble at 40mph to 50mph.   Awesome feeling.   I went from wanting to part ways with the jeep to being stoked about it again.   Without this article giving some direction this fix was not possible so thank you!
Another note,  I tried messing with the caster angle making it more positive ( by measurement from a chart ) but that seemed to have no effect on the wobble.
So,  the originator is spot on.  The front suspension must be tight.  Look for a shiny tell and fix it.  While the toe out is supposed to be a work around to hide something else that is loose,  I will take it as now the Jeep is a perfect ride at any speed.
Robert Sims
