Tranquillity
Hey guys thought I'd share some pictures about those fenders. If it can make you decide whether you like them or not. If you have any question I'd be happy to answer them.
Thanks for the pictures! This helps a lot. Hawaii state law requires the same ridiculousness, in which the WHOLE tire is required to be covered.
Can do you do a shot of the front tire (either side) and fender (like what you did with the rear right line up) and from above the fender looking down on to the tire. That's how they judge it at the inspection.
Appreciate the help man!
Here you go, should give you enough info.
As said that would depend of your offset. I run 315/75r16 duratrac with black rock 4.25 bs.
Those things are ugly as fuck. Thought they died off in 2014 when this thread was started.
It's like the pocket flare and the flat flare fucked and had an abortion.
