Ok guys....here's a weird one for you.
About three months ago, I had the ESP BAS light come on. So I checked all four speed sensors and wiring to each one. After doing so, the light went off. Then approximately three weeks later, the light came on again. But what was weird, is that it came on at the same exact spot on the freeway as before - on a bridge crossing the Sandy river. But this time, after I shut down at the airport, then restarted, the lights were out. So I pressed on. Then it happened again...same exact spot on the same bridge. And now has repeated the same behavior about 5 times. Same exact spot on the bridge, all different times of day. What the heck could cause it to happen like this? I'm likely to replace all four speed sensors, but am curious if any one has ideas as to why this is happening at the same spot every time and no where else?
Thanks! Ryan
Thanks! Ryan
