seanrugby11
I'm going to try and not sound like a newbie but I think I will anyways. Oh well. So I have a 98 tj and it was making a terrible sound while idling. Found out it was the flex plate. So had that fixed by a mechanic cause I don't have the time or a lift to do it. Got it back and it started misfiring. So checked out the cel found out the crank shaft position sensor was bad. So replaced that and gave the babe a tune up with new plugs and new wires. Started running fine. Kept the cam shaft position sensor that I bought with it just in case since that code was coming up too. Well it's snowing up here in FoCo so I threw it into 4 wheel on my way to school. Check engine came back on and it is idling harsh. I'm stuck. Is it the cam shaft or something else? Any help is greatly appreciated!
