olram30
Not That Kind of Engineer
One thing I did notice that's the DD long arm and not the High lift. Did EVO change the arms and not use the solid alluminum arms?
the envy arms?
This is the EVO MFG High Clearance Long Arm kit!
The ENVY Links (Aluminum Arms) are no longer available.
So the DD compared to the High is the same arms and the brackets are the only thing different?
I was thinking the whole time the High clearance is the Alluminum arms. I was really looking forward to getting that look along with that style....:naw::naw:
There needs to be picture changes id say.....:drama:
As said before a number of times in this thread, the ONLY thing different is the brackets.
The link on the ORE website states - "NOTE - SHOWN WITH OPTIONAL ENVY LINK UPGRADE"
http://www.offroadevolution.com/store/proddetail.php?prod=EVO-LONGARM-UPGRADE
Perhaps read the website description
Optional??
:flag_bs:...
Optional??
When you look at a website and it shows alluminum arms in every picture, what would you think and their's wording way down in the bottom that says other wise!!! :naw:
I sure I did read it but didn't know what ENVY links where...... I know them as control arms. I've been in this game for a good 6 months and learned everything from this site.
I know this has been talked about in other threads but I couldn't find it (and ORE guys feel free to jump in), I have the teraflex long arm kit on my jeep and was wondering....
1. Is it possible to change out the arms to evo arms?
2. What exactly is the difference from the teraflex and Evo arms (besides made in USA:thumb
3. Can you upgrade the teraflex kit in any way to get rid of the rear brackets that hang below the frame
Sorry to be repetitive and thanks in advance for all of the help.
in order to run the EVO MFG long arms, you will need either the DoubleD brackets or the High Clearance brackets. the EVO MFG will not work with your TF brackets. and so we are clear. The High Clearance kit is designed to be used with the EVOLever and will remove the REAR Lower Shock mounts and there is not a replacement mount unless the kit is installed at ORE.
Tube thickness and Johnny Joints are the main differences between the arms.
as far as I know, there is no High Clearance TF kit.
Thanks drew. I'm aware there is no high clearance kit on the teraflex, I've heard that ORE has done some customization to other teraflex long arm kits to help with the brackets.
