Yes you do
Yes you do
is it one or the other or is it both? just curious for if i ever pull the trigger on them. if its one or the other which one would you say is better
You need a pigtail to make it work. You'll want the modulation harness if you're one of the people that see the flicker and it annoys you. Most people don't see it and that's why it's an option.
Have these in the cart and there is a drop down tab with options.. pigtail harness and modulation harness. Do I need these?
I have the same second delay from high beam to low. Nothing major but concerned a little in that I don't want to annoy oncoming traffic. Is this in fact the modulator that causes this? Anyone know for sure??
I have the regular harness and have the same response from the lights. I have always assumed the delay is because the lights are LED controlled by a circuit board of some sort. Figured it just took it a sec to switch modes. I could be totally wrong, but I doubt it's the harness.
WAYALIFE APP![]()
