What axles do you have? I don't have an opinion other than; if it's a dana 30, do not go 5:38... The dana 30 ring gear is tiny and you don't want to make the teeth any smaller than necessary.
05 Tj, long arm, one ton, lockers, winches, 39.5" Iroks
I have a manual 2012 JKUR with 37" and 5.13 and couldn't be happier. I definitely think 5.38 would be too much. Not sure about ring thickness but that might be an issue also.
WAYALIFE APP![]()
WAYALIFE APP
Forget 5.38, the pinion on it is super tiny in a Dana 44 and it is something I have broken because of it. Have you guys ever seen what a 5.13 looks like in a Dana 30? Same thing! If you leave your front end open, you should be okay running it but if you lock up, I personally wouldn't run anything more than a 4.88 in a Dana 30 but hey, that's just me.
Eddie what do you recommend on a 2010 auto rubicon running 37's with d44 up front and rear
What rpms are you running at 70 and whats your gas mileage like? I have a 2012 manual as well and im still up in the air between 488s and 513s. If I lived in the mountains or higher elevation I would do 513s no question but im in the northeast
My RPMs are right around 2600 at 70 right where the 2012 Manual gears chart said I should be.
I run the 37x12.5s around 28-30 psi depending on where I'm going but I average about 13 mpg. The tires are NITTO Trail Grapplers.
5.13 is also better for towing, if you ever intend to do any.
5.38 would be a ratio that I would prefer BUT, I personally would not recommend anything bigger than a 5.13 in a Dana 44. I have tried running 5.38's and blew them out in about 2 months/9 nine hard runs. I should note that I was always aware of the likelihood of blowing them and ran them more as a test than anything.
So you suggest 5.38? Is that going to favor more toward highway use or off-roading, crawling etc.
I think he's saying 5:38 would be the perfect ratio if you had axles that could reliably run them.. (sounds like you need dana 60s to run 5:38s) If Eddie has broken 5:38s in a dana 44, they would never last in a 30..
I have d44 but yes eventually I'll go 60but I'm just wondering what I should go with for now I take my rig in next month so I'm just wondering what you guys run and if happy or not
I think he's saying 5:38 would be the perfect ratio IF you had axles that could reliably run them.. (sounds like you need dana 60s to run 5:38s) If Eddie has broken 5:38s in a dana 44, they would never last in a 30..
