Serg5000
My air bag light was staying a couple months ago and it turned to be the clock spring. Pretty common problem with the jk.
Thanks Tony. Guess I can't avoid changing it.
I am trying to figure out why my passenger airbag light won't go out. Comes off and on. Checked what I could and have come up dry. Someone suggested replacing the clockspring. I would like to confirm its the problem before spending $200+ on a new one.
Doubt if the clock spring would bother the passenger airbag.... maybe; but the passenger seat has a weight sensor that works in conjunction with the seatbelt sensor. One of them would be my best guess..... That is if the airbag itself is fine
Ok maybe I'm wrong. The light is coming on in the center of the dash. All it is, is a figure of a person with a seatbelt on and an airbag. In red. Not sure if it's the passenger or driver. This is on an 08.
I got the led strip at autozone, I bought the max bright one or whatever it was called. It was like 40$ or so. I used some 18 ga wire spliced it in to the dome light and grounded it under the passenger dash.
Got tired of loosing small things behind the dashboard so I filled the gap with small diameter gray foam pipe insulation tubing. I did take a razor and cut about 1/4 of the diameter away so it would fit with out much force. Isn't too obnoxious looking either!
That's a damn fine lookin' bumper. :thumb: My condolences to your wallet.A new ps rear bumper & tire swing for panda! Lots of work to install & wallet still hurts but worth it I think, works really nice!View attachment 57966
Are the lights in the bumper recovery lights on a switch or are you running them as back up lights?
A new ps rear bumper & tire swing for panda! Lots of work to install & wallet still hurts but worth it I think, works really nice!View attachment 57965View attachment 57966
