Rear corners ???
Do they still make the skins like that? I love the look!
Thanks for those pics. Are the outlaws still available?
Sent from my PC36100 using WAYALIFE mobile app
Pretty sure the builder flares are no longer produced or are special order production. Those are just the corner skins.
The builder flares are not a regular production item, they are considered a custom item. You need to contact EVO mfg about their availability. I just so happen to know a guy, who's 3rd cousin knows some chic, that knew some body in Fullerton, CA. that got me in touch with some dude who was able to get me my set......
Sounds like a pretty cool dude:D Great pic of your Jeep.
2011 JKU 3.5 R.E. Longarm lift.
<img src="http://wayalife.com/attachment.php?attachmentid=54368"/>
<img src="http://wayalife.com/attachment.php?attachmentid=54369"/>
Dam:/ I gotta get in touched with my cousins lol
The builder corners like on Greg's jeep are usually in stock. (Plain, no fender or lower tube)
When you decide to add the flare the build time is extended at Evo mfg as it's not item that goes into production on a regular basis. The tube on the lower is only available if installed at Off-road evolution
Is there a 2 door version of the builder corners available ?
the corner/flare combo would be considered a "custom fabrication" job and as Chris mentioned, would only available at ORE. as for the 2dr corners, the standard EVO 4dr and 2dr corners are the same.
Hey Drew, it's jeremy over in virginia, the guy you been talking to about the sway bar links and I had ordered the slabs last week. I'm the OP here and would love for you to pm me an estimate on the fenders gcm2 is running with the tubes on the bottom just like in his pics. If you prefer me to call, just let me know
Could you tell me how much lift you are running? Also, I'd love to hear some feedback, pros and cons on running these corners without flares with the exception of being illegal ;). And if you have more pics of your jeep, could you post them? Your jeep, well, just might be my inspiration :brows:
Jerms, you can actually see his jeep in action on the last two JKX's, Keep it Tight and the heartland. They are on the WAYALIFE YouTube channel. Also check out the thread Soap(not TV).
Jerms, here is the catch with the builder flares I'm running.....the cool little tubing added to the bottom is only available if the install is done at Off Road Evolution (I think? Drew/Chris please confirm). At least when I bought mine, I was told by Mel or Lisa at the shop that the tubing is added AFTER the corners are initially fitted, just before final install of the corners. I think if you buy the builder flares and have them shipped to you, they will come without tubing. You can see my flares are completely fitted, but have no tubing added yet.
Currently my coilovers are dialed in to run about the equivalent of a 4" traditional coil spring lift.
Pros- looks badass, great protection from damage, little to no maintainence, nothing to get ripped off in tight spots, since it covers so much surface area (unlike bolt on flat metal tube fenders) in the event of a strike or rollover it will disperse energy throughout the quarter panel since it is now really the entire new quarter panel.
Cons- no flare could be illegal in your state, adds a bunch of weight, lack of flare really not advisable unless you live in the southwest where it never rains or has mud because your jeep will see major tire slinging ugliness
The corners saved my jeep from any serious damage after this flop
Does EVO still sell donuts too?
Yes, but only buy them when the red flashing light is on......that's when they are hot and fresh!
As stated earlier that bar on the bottom can only be installed at ORE. It can't be done unless its on your rig.
